My sister recently asked me to build her a PC. Her budget is $900. She won't be doing anything else than gaming mostly. She wants the pc to be compact/small and black. Couple of pointers I'm buying the CPU without the box aka tray version with a deepcool cooler so buying those two would cost the same as buying the CPU with the box.
https://fi.pcpartpicker.com/list/jQdLTY
https://linustechtips.com/topic/1570447-build-for-sister/
I like this build a lot 🙂  You did your research and picked good parts.
Not much I would change if anything.  You can save a few bucks by going with some slightly cheaper memory but thats about it.
https://linustechtips.com/topic/1570447-build-for-sister/#findComment-16411145
oh yea forgot to mention the memory. That's the cheapest 6000 cl30 ram i can get in my area
https://linustechtips.com/topic/1570447-build-for-sister/#findComment-16411148
Have you considered the Asus AP201 for this build?
ASUS AP201 Type-C Airflow-focused Micro-ATX,Mini-ITX Computer Case, Support 360/280 Liquid Cooling - Black - Newegg.com
Its a bit more compact of a case but slightly more expensive. I think it would be worth it if she likes the design better.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1570447-build-for-sister/#findComment-16411165
I like that case
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1570447-build-for-sister/#findComment-16411216
board is a pretty awful choice, vrms are weaker than the b650m hdv and its an a620 chipset not to mention that it doesnt even fit the aesthetic, my reccomendation would obviously be the b650m hdv or an equivalent board, and 2 rgb rams will look better on a board with only 2 slots
ssd is meh cause dramless gen4 so look for a dram gen3 like the exceria g2 nm620 m371 tempest etc.
if the 6700(xt) is available new then get one of those instead as theyll outperform the 7600 and have more vram
otherwise build looks good
https://linustechtips.com/topic/1570447-build-for-sister/#findComment-16411281
