A good X570 motherboard with 2.5Gb LAN
9 hours ago, QuantumSingularity said:So guys, long story short, my ISP contract was about to expire, so i re-signed it and got a sweet deal on 2.5Gbps connectivity. Wednesday the guys would come to replacing my fiber optics and i started looking for 2.5Gbps PCIe cards. Unfortunately there aren't many of those around, like just 2-3 extremely sketchy sounding brands, the majority are 10Gbps and their prices are the same as a new X570 motherboard or higher. And with very VERY rich choice of 2nd hand X570 mobos here with warranty, i decided to change the motherboard with something that has onboard 2.5Gb LAN. But as it turns out, 2.5Gigabit LAN isn't that common on X570 boards. So what is a good board to get? My only requirements are - a minimum of 2x M.2 slots for NVMe drives, 2.5Gbps LAN and absolutely no Asus motherboards. Don't care about the brand as long as it's not Asus, although i'll still be happy if it's an AsRock mobo (and yes, i checked the Taichi models, they have only a Gagbit LAN).
This is one I've got that fits the bill of what you're looking for. I can vouch for it being a good board because mine has been, even under subzero conditions and it has yet to miss a beat.
MEG X570 ACE | Motherboard | MSI Global
Check it's specifications and I believe this will do it if you get one.
However this isn't the newest iteration of this model line, there is another that took it's place afterwards but that one should be just as good as long as it's specs satisfies your requirements.
MEG X570 UNIFY | Motherboard | MSI Global
