Need help confirming cable for MSI GTX 1070
cyf
I just "inherited" an MSI GTX 1070 ARMOR 8G OC (Micro-Star model no. MS-V330) link to likely product specification and I am trying to connect it to my power supply, which is a Corsair CX-500M link to product specification.
I have a cable with the following connectors:
All 3 plugs (left [6+2], middle [6+2], right [8]) can be plugged into the graphics card.
The plug on the right [8] is not insertable into the power supply (there's a plastic tab between the 2 square pins on the top right), but can be plugged into the graphics card--thus, the left and middle plugs can be plugged into the 8-pin socket in the power supply.
Can I plug the plug on the right into the graphics card and the one of the other (left or middle) plugs into the power supply?  My understanding is that the 6+2 plugs are normally for the graphics-card side, but it seems like in this case, it's the reverse.
Edit: The cable I show is definitely not from corsair.  I will contact them as you guys suggested.  Thank you!  (I realize I can make my own cable, but I'm too lazy to do it at this point.)
Are you certain that this power cable is original to this power supply? That 8 pin should absolutely go into the PSU.
Primary PC:
According to the picture from their product page the cable seems to should say "pcie" not "vga."
CX Series™ Modular CX500M ATX Power Supply — 500 Watt 80 PLUS® Bronze Certified Modular PSU
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Yeah I am thinking you might want to reach out to Corsair support and see about a replacement cable for this power supply. Their customer care is pretty good and they might replace your cables free of charge.
Primary PC:
The cable is DEFINITELY not from Corsair. I will reach out to them.
