Wraith Stealth fan on tower cooler
CrazySerb99
Hey everyone!
The fan on my cpu cooler has been getting a little noisy, guess the bearings got shot.
So I thought of clipping the wraith stealth fan onto the tower cooler.
The cooler is the lowly Antec A40 Pro but it's cooling an R5 2600 so the temps are perfect.
The wraith stealth fan seems to be 96mm but the mounting holes seem to be fitting the 92mm fan, so it should fit nicely (the stock fan was mounted with rubber pointy things I would re-use).
Any opinions on how this would perform?
Cheers!
3 minutes ago, CrazySerb99 said:
Hey everyone!
Cheers!
Get a better cooler, a TR Assassin X is $20
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
€35 in my country, plus I already have the wraith stealth fan in hand. @PDifolco
Why not just do it and TELL us how it performed?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Why not just using the Wraith stealth then ?
Will do in about a few hours, just wanted to hear some opinions first.
Noticed that people are pretty divided about that fan, some say noisy as hell, some say its perfectly quiet.
 Well a 90mm fan is either noisy or idle 😛
Well, then I'd be going from a tower cooler to an aluminium block.
Downgrading the fan I'd see as okay, but the whole heatsink, idk...
Ok, you can test it anyway, not sure anyone  here did that and has real insight on this 🙂
Well the factory cooler fan for the Antec was actually the most silent part of the PC 🤣
Try the AMD wraith fans, else get a cheap Thermalright 92mm fan
Upon opening the case and comparing the stealth fan and the factory one, I found that the stealth is the same size for the fan itself (blade size maybe even slightly larger), however the mounting holes do not match up.
The factory fan is the standard 92mm fan and it has the regular mounting holes, while the stealth has smaller corner edges which brings the mounting holes in.
instead of the holes being 92mm x 92mm I found they are closer to 75mm x 75mm for the stealth.
A new 92mm fan it is! (for anyone interested).
I am not familiar with what the fan looks like when its removed from the cooler.. but is there any way to get creative with zipties?
There are a few ways to mount a fan with zipties, a couple of them are ghetto af but  works.. sorta.
AMD R9 5900X | Thermalright Phantom Spirit 120 EVO, T30,TL-C12 Pro
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
