Deepcool AM5 Thermal Guard
TatamiMatt
Just found this interesting bit of equipment, its a thermal paste guard much like thermalrights for AM5 however it is much less intrusive and made of copper
Seperate to the not needing to clean thermal paste as much when replacing etc etc that a thermal paste guard usually does, this seems to roughly match the profile of the contact plate of a cooler and the fact that it is solid copper, would the extra material allow extra heat spreading from around the sides of the IHS where the cooler doesnt touch and conduct it into the cooler, effectively upgrading the surface area of the IHS and allowing a greater heat conduction area into the cooler? Or is this redundant enough to not care (only about £8 or $10 where i live)
To further that thought, would this benefit coolers like the Phantom spirit or MA824 where there are enough heatpipes that some of the Heat pipes are actually far enough away from the IHS that they may not make much contact at all?
Whats peoples thoughts on this?
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Seperate to the not needing to clean thermal paste as much when replacing etc etc that a thermal paste guard usually does, this seems to roughly match the profile of the contact plate of a cooler and is made entirely from copper, would the extra material allow extra heat spreading from around the sides of the IHS where the cooler doesnt touch and conduct it into the cooler, effectively upgrading the surface area of the IHS and allowing a greater heat conduction area into the cooler? Or is this redundant enough to not care (only about £8 or $10 where i live)
Interesting. Alternatively you could get the contact frame as I would expect it to perform better.
Haven't seen any reviews on the deepcool frame /guard. Its more a guard than a frame. Look at the massive edge around the cpu vs contact frame:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
Yeah, honestly its less of the thermal paste situation, what piqued my interest is that its a lot more flush with the surface of the IHS and copper based, if i were to put a little paste on the copper itself and spread it around before mounting, would that increase the coldplate to IHS contact surface and improve thermals? As the other one wont touch no matter what you do, even a 1mm+ gap is too big, whereas with the deepcool one it looks maybe 0.3mm? much more doable to bridge with thermal paste and possibly increase cooling efficiency and heat dissipation from the IHS
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Idk if that would be the case in reality. I see your point, but using a thicker layer of paste will result in higher temps than thinner layer. Also the copper plate is not directly connected with the CPU heatspreader apart from in the corners, so I would expect it being pure copper to just be marketing:
FS in Denmark/EU:
All these prevent is thermal paste getting in between the edges of the CPU, at least to some extent. They serve no other purpose. Having owned two AM5 CPU's now I see no reason to bother. Noctua makes one too.
https://noctua.at/en/noctua-presents-na-tpg1-thermal-paste-guard-for-amd-am5
Just more crap they can sell to people.
with a different thermalright mounting guard/frame (that doesn't seem to be copper) about 50 points were gained in R23 with a 7700X and temps were about 0.2 degrees lower. But this being copper, I think would make a larger difference, but I think it's still mostly for not excessive spreading into the sides of the CPU
it's possible, in the screenshot above an AIO was used and it couldn't reach the sides of the guard so with an air cooler that has heat pipes on the sides it should, even if it doesn't you're still protecting your CPU from getting thermal paste in places where it shouldn't be
is this thermalright frame useful at all? in the picture the IHS is extending over the top of the contact frame so wouldn't the CPU Cooler just not touch that at all and just touch the IHS?
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
The point of contact frames isn't for them to touch the cooler, it's to hold down the CPU evenly from all around instead of just from 2 tabs like the stock mounts and avoid bending the IHS. It'd be impossible to make something that touches the cooler perfectly without making the CPU-cooler contact worse with manufacturing tolerances.
It's been shown to be beneficial on LGA1700 so manufacturers probably figured they'd just make some for AM5 while they were at it and people will buy them even if AFAIK no benefit has been shown there.
The guards don't do anything about that or thermally.
F@H
GPD Win 2
1 hour ago, Tan3l6 said:
I think the good old AM5 secure frame like this is a bit better:
https://www.thermalright.com/product/am5-secure-frame-red/
Though have to swap out all of the mounting mechanism.
More a matter of preference than performance though.
Some reviewers have demonstrated that contact frames are important for your Intel CPUs, but not AMD. They are just an extra expense if your CPU doesn't get really hot much, as I learned when I tested the TR LGA1700 BCF with my very tame 12700k.
Now, the frame that is needed for AMD is the offset frame for coolers that were designed with Intel's centralized chips in mind instead of AMD's offset chiplets.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Considering the goal being lower temps and better contact  between IHS and the cooler, then sure AM5 one hasn't got much point, but considering the reduction of thermal paste drippage it still performs good, I believe as good as the smaller frame pointed out by OP.
Has at least as much function as LED show in some cases, perhaps even more, as it has a physical function rather than aesthetical.
I edit my posts more often than not
youd probably find more benifit glueing on a heatsink to the back of the board on the retention mechanism backplate and pointing a fan at it since the retention mechanism does have direct contact with the cpu and ive definitely felt these getting hot when running the cpu without a heatsink but probably not gonna be that big of a temp diff
does it allow for lapping the cpu ihs thinner than the stock retention mechanism? if yes then it does have a use for ppl that dont wanna delid + direct die but still want lower temps and be able to use more powerful coolers whilst actually having an effect on temps and not just wasted cooling power that goes unused cause of garbage heat transfer from the cpu die -> cooler
Yes that's the point. Having the cooler touching anything else don't yield anything cooling wise
FS in Denmark/EU:
Thanks everyone for clearing that up. I can now confidently say I learnt more reading these than in my Computer Science lesson 😄
Sorry for the confusion 🙂
Current parts list
No disagreement there, but I'm not sure the cleanliness benefit is worth the price for someone on a limited budget.
