Better fans or better cooler?
4 minutes ago, filpo said:Current build: First SFF build - PCPartPicker (all I've changed is swapped the side intake for the Noctua P12 Redux that was up top and put the arctic fan there)
Thats the login page
4 minutes ago, filpo said:So I've basically got two choices, upgrade the cooler to something like the thermalright Phantom Spirit 120 SE (which would be perfect in terms of height and is good for value) or get quieter fans (this is the worse option IMO but I will still have the low height from the wraith stealth (though I'm not planning on vertical mounting my gpu so it's not really useful)
Just get a bigger cooler that wraith stealth will only do a TINY bit better with a better fan on it. It's a basic simple cooler lacking the surface area needed to cool any better really.
5 minutes ago, filpo said:Any thoughts on RAM clearance though? It's good I've got vengeance LPX but even still it looks like the fan will protrude it
You can move the fan around if it is in the way. This cooler also works fine with a single fan. Especially for such an easy to cool cpu like yours.
