Modding an 10GB 3080 to an 12GB 3080, possible or bs?
1 minute ago, Hinjima said:So its definitely possible
Not necessarily. All of those cards have replaced all the VRAM, ignoring any extra pads that are in place. AFAIK Nvidia does disable those two pads on the silicon itself, they're only there because companies like Zotac, ASUS, EVGA (RIP), etc. want to reuse the PCB from the 3090 on the 3080.
Look at the 2080 Ti 44GB edition, that does have an extra pad, but it wasn't used to make the card a 48GB version.
OP, if you're willing to replace all the VRAM on the card, sure you can probably end up with a 3080 20GB, but using those extra two pads to end up as a 12GB is not likely to be possible. Also, just to point out, doing BGA soldering on for things like memory chips is pretty difficult, especially on GPUs where the PCB is designed to withstand 300-400W of heat regularly.
