PSU "CLICK" sound when turning on/off
J3Tear
Hi, I just bought new  MSI MPG A850G PCIE5 850W and barely installed it. I'm 100% sure that everything is connected well. This click sound happens only when turning on or off PC, and it's just fracture of a second, everything works and sounds normal so IDK if I should be concerned.
That's most likely the sound of a relay turning on/off, and it's completely normal. I have multiple power supplies that make the same noise.
Computer engineering grad student, cybersecurity researcher, and hobbyist embedded systems developer
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 16GB DDR4 3200MHz C16
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16
My SF750 has a distinct relay click, I actually like it.
