Will 4K KVMs work with Samsung Odyssey G9 OLED Monitor?
1 hour ago, MadManMoe said:I hate long posts, so I'll try and keep this short (prefer replies from those who have experience with the G9).
Current Setup:
- (For Work):
- Model: Lenovo Thinkpad T14 running
- CPU: AMD Ryzen 7 Pro 5850U
- GPU: Dedicated Radeon Graphics
- OS: Windows 11 Pro
- (For Home):
- Model: HP Z840
- CPU: Dual Xeon E5-2643
- GPU: Radeon RX 6700 XT
- OS: PopOS Linux
- CKL 2 Port KVM switch
- Samsung Odyssey G9 OLED Monitor (Model: LS49CG954SNXZA)
Previously, I've had two Alienware 27-inch 1080p monitors that worked without a problem...until i replaced them with the G9.
the TL;DR of it all is I spent hours mixing...altering...moving cables and setups and wires around, until I went flat out cave-man and connected my work laptop using HDMI and my home PC with the included DP cables...but now...my KVM is basically an overpriced KM instead of a KVM switch.
My questions are:
- is the G9 so finicky and so sensitive, that it just refuses to cooperate with most KVMs (not enough resources out there, but seems to be an issue)?
- My home machine is running Pop OS. Direct connection using the included 8K DP cable, I get at best 120Hz with full resolution. @ 240Hz the screen goes mad and flickers on and off every 2 seconds. is this an OS issue or monitor issue or PC issue? (Laptop runs fine at 120Hz using HDMI which is perfectly acceptable for me).
- Rumor has it the G9 has a built-in USB switch/hub. Nothing in the included documentation says anything about it. Anyone know anything about it?
- Finally: Do I just need to rip out all my wires cables and replace each one with an 8K certified cable? Is that really my issue?
Thanks in advance Fellow tech guys.
I should note on the product page of the KVM it says:
QuoteSpecial Reminder on 5K resolution: This KVM switch does not work for 5K (5120x1440 or 5120x2880) over 100Hz, recommended is 50/60Hz. Please be aware of this before order.
