buying advice Which one? GeForce 4070 TI or Radeon 7800 XT for the SAME PRICE
8 minutes ago, 8EK3 said:So I have two options,
I could get a new 7800 XT new, which is a quite recent card, or I can get an used 4070 TI for the same price of 550 $.
It is this specific card: AORUS GeForce RTX 4070 Ti ELITE 12G
What is your opinion?
Pros & Cons?I know my components quite well, but I am not so sure about the graphics card.
The 4070Ti is the fastest card out of the two in pure performance.
Its also a lot faster in RayTracing if that is something you want.
I would get the 4070Ti.
Be aware that Gigabyte 4000 series GPU's have had issues with the PCB cracking near the PCIE slot so use the antisag bracket that comes with it if you can.
It shouldn't throw you off on buying a Gigabyte card, just keep it in mind.
