Building around Ryzen 7 5800X and RTX 3070
Solved by wONKEyeYEs,
34 minutes ago, Teejo said:GPU: NVIDIA GeForce RTX 3070
CPU: AMD Ryzen 7 5800X
I have a system using those.
Look in my signature for specs.
I did not buy for price so it certainly could be done cheaper.
The CPU cooler could be a decent tower instead of an AIO, and of course you wouldn't need the riser.
Trident Z is pretty good memory for 5000 series, you might want to get 2x16GB though.
A B550 board for one to two hundred $ would be fine.
My system can pull about 500W at the UPS, including monitors.
A 650W PSU would probably do.
