So I did not go crazy with taking pictures since I was so focused on getting the build done.
Parts list
800D
i5 2500k
Asrock Extreme 4 gen 3
EVGA GTX 670 FTW W/Backplate
G Skil 2x4GB 1600
Corsair AX850
LG Blu-ray player
Samsung 128 830 (boot)
Crucial M4 256 (games)
WD 1TB Caviar Black (music & movies)
WC Parts
Koolance 360 rad
Swiftech Apogee HD
XSPC GTX 680 Block (FTW fits 680 Blocks)
XSPC High Flex PVC Tubing - 1/2" ID (3/4"OD) - Blue / UV Blue
Scythe Gentle Typhoon 120mm x 25mm Fan - 2150 RPM x3
Lamptron 30W - 4 Channel Aluminum Rheobus w/ Multi Color Backlit LED - Version 2 - Black (FC-5V2)
Koolance PMP-450S Pump
Koolance RP-452X2 Dual 5.25in Reservoir for 1-2 PMP-450/S Pumps, Rev.2.0
Swiftech ½” x ¾” Lok-Seal™ Compression Fitting x8
Silver killcoil
I am not very interested in spending all my time with cable management. I am very happy with how easy it is in the 800D.
My temps are 38 C on the GPU at full load and 62 on my 2500k.
I did lose the silicon lottery. My i5 maxes at 4.2 GHz and will crash at any clock higher than that. LAME.
I am going to wait for Broadwell or Skylake to upgrade my cpu.
post-18821-0-38134300-1368380202_thumb.j
post-18821-0-48053900-1368380244_thumb.j
post-18821-0-46228900-1368380560_thumb.j
<p> AMD Ryzen 7 5800x l ASUS TUF X570-PLUS l G.Skill Trident Z Neo Series RGB 32GB l Sapphire Pulse RX 7900 XTX
https://linustechtips.com/topic/15629-another-800d-sleek-and-simple/
Nice rig, how high you get the 2500k?
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
looks cool. i am kinda noticing that a lot of people are doing blue builds.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
everything is blue or black except for the RAM...
Yeah well I ripped all my parts from my old system that was not photoworthy. I will upgrade the RAM after my 1440p monitor arives.
You cant tell in the pictures but it is UV & Blue lights. The tubes are UV blue and with the blackout shade I bought for my dungeon it really stands out.
Sleek and simple, just like what the title said, I liked it.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
Sexy :3
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
