Need help choosing the correct RAM
Solved by ShadowCaptain,
Hey, I just wanted to know which memory is the best according to the specifications of it like timings and volts. The motherboard I will be using is the ASUS Maximus VII Ranger z97 and the CPU will be the i5-4670K. The system will be mainly used for gaming.
Makes near as no difference for gaming , (also I have this ram, its amazing)
I am using the 2400mhz because a few programs (and BF4) take advantage of it, the 1866mhz kit is probably the best though, as it has low timings but still with a fast frequency
