Power suggestion Galax Sniper GTX 950 6pin
Solved by Blasty Blosty,
5 minutes ago, SwahowMajin said:Hi,
I need some advice/info.
I bought a GALAX Sniper GTX 950 with a 6 pin power port
I want to use it on a Dell Optiplex 790 i5 (it will be temporary) problem is I am not sure if it will work and also not sure if it has a 6 pin on the power supply.
If the PSU don't have the required pin connector, will it still power the GPU enough to be used?
Note I just upgraded from a GT640 so realy want it to work
I do not think those PSU's come with a 6 pin PCIe power cable, so the card will not work, it needs the external power to run.
