Cooling in an O11 Dynamic mini
6 minutes ago, FH11 said:Great, ill check that as soon as I get home. Do you have any advice on how to mount the fans? Radiator between fans and case or fans between radiator and case, how many intake and outtake, etc.?
Fans pushing will generally always provide more airflow and pressure so radiator between fans and case, and rear exhaust fan will be just under 4 exhaust fans worth as radiator will inhibit airflow. So you could do 5 intake if you wish, 3 on bottom and 2 on sides, but you could also do 4 intake however you wish and youll still have positive pressure. Positive pressure will net you a tiny bit extra cooling, in reality you wont notice any meaningful difference between negative, neutral or positive pressure, but positive pressure keep the air flowing into the case through dust filters so will keep your pc cleaner and dust free for longer
