What exactly does 3 slot wide gpu mean?
Solved by Eigenvektor,
2 minutes ago, Fat Cat11997 said:Could this affect whether or not the gpu even fits? like if there's the primary slot that's the fastest and meant for the gpu, but then there's a large space between that slot and the other 3 slots, would that mean any capictors in that band between the slots would get in the way of the motherboard causing the gpu to not fit?
The motherboard itself generally should not block the card in any way. But e.g. for a mini-ITX board the card would be larger than the board. The more common issue is the card not physically fitting into the case, but that's usually more an issue if the card is especially long, rather than thick.
