Any plans for LTT to add a small box of common screws used in PC building and repair?  Would be a great addition to the screwdrivers.
This sort of thing does exist, but is commonly a cheap translucent plastic box with dividers for different screw types.  The issue with existing products on the market is that they are not clearly labeled, and/or the mix of screws isn't good and there are useless (waste of money) parts in the bundle.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/
Never used iFixit screwdrivers kits ? they're pretty good in my book
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336838
I don't want a screwDRIVER kit, I want a kit with screws.
Like this.
https://www.amazon.ca/MMOBIEL-Standoff-Computer-Motherboard-Graphic/dp/B08F4FLD4C/
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336845
Like this.
Huh ok, sorry for the confusion 😮
But i can't really think what can be done  better on a screw kit  ...
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336847
As per my original post, they are either they are poorly labeled or the mix of screws included isn't good, and many have a few useful screws, and the rest are useless parts.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336851
I've bought a few of the 10$ boxes and they've been pretty good and universally come in well labelled individual separated sections. One problem is that different companies use different standards. There are two flavors of mobo standoffs with their own screws to match. There are at least 4 different types of m.2 standoffs. PSU screws are universal as are the self tapping fan screws, but case screws vary from company to company. Then you get into the whole world of radiator screws which come in many different lengths.
I think the problem is that it's impossible to make a comprehensive set of screws without including a LOT of "useless" pieces.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336908
I'm fine with it not be comprehensive.  I do not want to pay for useless filler parts.
I want two things: well labeled (pictures of parts, part # for reorders, name of part) and a curated assortment of useful parts without anyone of them being cheap filler.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336917
Okay, but what you call cheap filler, another consumer might call the most important part.
How about this one? https://www.amazon.com/Standoffs-Assortment-Universal-Motherboard-Installation/dp/B09BD7Y13P/
As for part numbers, do you mean like "M3x10"?
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336931
Gaskets are a waste imo.
Part number would be an a number used to reorder more when you run out.  Could be a barcode or QR code.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336937
Yeah, I really *really* don't think LTT would or should enter this market. It's just not worth it. Especially with your requirement that they also sell screws individually. This is a razor thin margin business and it's well served by the existing market
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336965
I think you are very wrong about the margins on this.
The product you linked me, is $20 + $5 shipping in Canada.  The cost of goods is less than $5 landed cost.  It's a few bags of screws and cheap plastic case with a sticker.
With a moderate take rate from screw driver customers, this is a nice additional chunk of revenue.
People would have said the existing screwdriver market was well served by the products in existence before LTT sold millions of dollars worth.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16336969
With a moderate take rate from screwdriver customers, this is a nice additional chunk of revenue.
Sure, the COGs is super low, but labor is gonna be the killer, especially if they stock both whole kits plus individual screw bags.
If you're really in the market for a screw kit with absolutely ZERO waste, I'd rec just buying a small tackle box and making your own for the brands you encounter.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16340936
You know if they made one, half the Internet would point to the existing generic PC screw kits (available just about anywhere for short money) and yell about how much of an "expensive ripoff" the LTT screw kit is by comparison.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16341268
That is what happened with the screw driver, but the still sold a bunch of them and continue to do so.
Listening to the haters can be foolish.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16341292
9 hours ago, tkitch said:
There's no way to get a "custom mix" of screws to be exactly what each person needs without having a stupid high labor rate.
The generic mix (with some potentially useless bits) is better usually due to costs
im not asking for a custom mix.  im asking for a curated mix of parts by people that actual build and fix PCs, not just some businesss that wants to sell the cheapest junk on amazon.
A good generic mix is all I am asking for, not some custom mix.  Everyone can easily do that themselves.
I just want to be able to buy something that isn't crap. which doesn't seem to exist.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16341913
Don't have to stock the individual replacements.  Can drop ship from fastener companies that make fasterns and bits their business or get affiliate referral revenue for directing customers to a partner.
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16341915
LTT doesn't drop ship.  And I honestly don't want them to start.
So, what exactly do you want?  Because you're making vague demands and not actually stating anything useful.
Quick amazon US search:
This is a perfectly reasonable kit.  10 bucks for 400 pieces.  Gaskets?  Meh, whatever.  But at worst that's like a buck or something out of here?
Everything else is fine.  LTT isn't gonna want to compete with that.
Here's a slightly more expensive option, at 13$ for 500 pieces:
What's different:
Colorways for Fan Screws, Thumb Screws and motherboard screws.  Eh, that's fine.
The nuts and bolts?  Slightly odd choice, but I've actually used those in my builds before, so it's not outlandish to include.
Two different Mobo Standoff threads?  Yup, not all boards have the same tray threading, that's a thing.
What are you actually looking for that would be materially different than these?  Can you actually answer that with something concrete.
And as far as "Isn't crap"
They're fuckin' PC Screws.  They're shitty commodity items, you aren't gonna get boutique luxury screws.  (Not counting when Lian Li made some custom anodized aluminum thumb screws, those were sick back in the day.)
https://linustechtips.com/topic/1560626-pc-repair-screw-kit/#findComment-16342001
