Smart Home application to associate multiple different smart devices
Hey guys,
long time ago in terms of videos of LTT I watched Linus creating (well, Jake was the one who did that) his own server with some kind of smart home app that was able to receive input from basicaly any smart home hub/appand then provide input to different smart hub/app. I spent hours trying to find this app, I belive it took place in Linuses old house.
Basically what I am looking for if anyone can tell me if that is possible or not.
I have bunch of smart items in my home but using multiple apps to controll those. I have xiaomi where I am forces to use Xiaomi home, I have LG, I have Hue lights etc. Now I am moving houses and I plan to do this right. I belive there is a software I can install that will be able to set communication betweek theese devices. Yes everything new will be Matter enabled but I need to make the old stuff work.
I preffer something I can install on either some kind of small server, tiny desktop, synology etc.
Thanks
Home assistant is what you want. Itll run on anything, and they even sell little raspberry pi like devices directly from home assistant: https://www.home-assistant.io/yellow/
Or yuo can run it on a pi of your own, or as a VM, or bare metal.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
If you have a TrueNAS machine, there’s also a home assistant app that you can install
