Upgrading my core to AM5 using Newegg combo deal, think it's worth it?
Solved by 191x7,
2 hours ago, zdemigod said:I have a 5600x, a x570 gigabyte elite wifi and Evga bronze 850w
The mobo has the top slot wrecked it only works on the bottom slot, my primary reason to upgrade
I could just replace the mobo and upgrade to the 5800x3d but by then it's already like 500 bucks
Check the combo deals too.
A good B550 board might cost you $150 and an 5700X3D about $200.
Yeah, it comes to about $400, and you get a 7600X to 7700X level of performance - but you get to keep your RAM, OS, installs, ...
