Can mesh APs connect to router via MoCA splitter, or must APs be downstream of main AP?
The answer is Yes, all other APs do not have to be downstream from the main AP.
On 2/13/2024 at 12:26 PM, NobleGamer said:Would things operate normally to move the main AP to a different room on the same Coax splitter as the other APs, such that the APs would no longer be downstream from the main AP?
On 2/16/2024 at 7:55 PM, Falcon1986 said:Well, Asus's AiMesh is a unique mesh system. Wouldn't be surprised if newer generations of AiMesh can interconnect like this.
How I confirmed this: I had to temporarily move my primary ISP modem to the basement, where there is no AP. So the topography is now this: One ISP modem > Edgerouter-X -> Ethernet switch -> MoCA Adapter -> 1:4 coax splitter (two goes to MoCAs for other APs) -> A main and secondary AP for each of two rooms.
For my mesh hardware, the main AP (SD4R) must be accessible by the other APs for those other APs to work.
