Monitor Arm for Thin Desk?
Solved by VIVO-US,
7 hours ago, Poinkachu said:They're industry affiliate IIRC.
@VIVO-US is their rep account name in this forum.
Usually they respond pretty fast when tagged.
Our clamp-on monitor mounts can all fit a 0.6" (5/8") thick desktop, although how well that works without additional reinforcement can depend on factors such as the monitor weight and arrangement. For desks that have a metal frame underneath, we've often recommended using wood blocks to help the clamp fit around the frame, and this works very well while adding reinforcement as long as the total thickness of the desktop with frame is within the specifications of the clamp.
