Very New to "Improving" my audio experience and need some basic advice
Chris Fortune
I am about to take my first steps into the realm of "low end audiophile" headphones and have been watching reviews and doing my research but I am ending up way more confused than I was with just using "good" junk headphons.
What I am looing for:
Good base response for music
Lagless audio if wireless
Budget: £300 max (kinda will creep over but not much)
What features are you looking for? bass response isn't a lot of information to go off. Noise cancelling? Wireless or wired? Really good soundstage and imaging? There's a lot of good headphones around this price bracket that do different things better than others.
Not bothered about wired/wireless as long as wireless is also lagless
The area I am looking to step up is for listening to music and I have a preference for base heavy music and want to have a less muddy base whilst not loosing too much top end.
If getting lagless audio requires a base station and it will be laggy on portable then that is OK as when mobile I don't watch accompanying video whilst listening
The other side of it is I am not sue what questions I should be asking to get where I want to be and whilst reviews have been useful I am finding myself more and more lost at the same time
Last point I want to be able to push the volume without distortion, I often will be looking at late night use so want to avoid annoying others whilst still getting the fix I need
The big one i'm thinking is noise cancelling, something like an Audio Technica R70X or FiiO FT3 would be my first recommendation to anyone in the £300-ish price range but they're both completely open back (all outside noise goes straight in and in really quiet environment people might be able to hear what you're listening to, it really benefits all aspects of headphone sound) but they also have no volume controls, something like an Audeze Maxwell is an easy recommend but they tend to sell for more than MSRP and also have a backlog when ordering (if you can find a pair in budget get the PS version unless you use an xbox console)
I am not bothered with ANC or even passive noise cancelling as a feature, I am not concerned if it is there just not bothered if it isn't. That said if having it is going to fundamentally improve my experience then yeah I want it but my experience so far has been less than favourable.
I have seen good things about the Maxwell but as you suggest they are a little over my hoped for price point. Will the PS version work with PC?
With the USB dongle included yes, the xbox version has dolby audio licences (PS doesn't, but dolby audio in headphones is kinda bad) have you been to any audio stores? I know that Richer sounds has a pretty good variety of headphones that they'll let you demo, along with carrying both versions of the Maxwell incase you decide to buy a pair and want a warranty.
I have recently found out about Richer Sounds as in today and will be paying them a visit as soon as I have some time off. Good to hear they have demo units as that will likely help me nail down things way better than just talking about it. With that said thank you for the talking too
Being able to listen to something is key, but do as I say not as I do lol.  I entered this hobby with a "reference" pair of headphones and never looked back, at those headphones or my wallet.
What kind of music do you listen to?  Because I feel this cliche aspect has been ignored to much however my own and @Cocococo's tastes are rather different, he says that the Rode NTH-100 is upper bass/lower mid bass heavy, and after some thought I agree.  But to me this is nothing but smooth richness in everything I listen to.  But I listen almost entirely to technoesque muisc and it doesn't ditract from a single thing I listen to.
If you want brain pounding bass... Then Beyerdynamic dt880 edition 600ohm is what you want but good luck driving them.
Lower bass or sub bass almost isn't a thing in headphones because of physic's, you can't do what a subwoofer would because it's shaking your body and the whole room, no bueno when just around your ears.
Bass is a very tricky thing to do with headphones and you need to learn what to expect.  Like I said I went into this wanting to experience what I could so that I could compare and contrast with reviewers.  Then there is the problem that most reviewers will not mesh with your own views, so your back to relying on buzzwords or a reviewer that shares your taste.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Well I was able to pay Richer Sounds a visit and true to the expectation they were knowledgeable and had units to be tried out. In the end I opted for a set of Bowers and Wilkins Px7 S2s which fitted my head comfortably and gave me a sound that I am really enjoying.
Congrats, hope you enjoy them
