Plzzzz help anyone
Solved by Middcore,
We can't see how the case front panel connectors are hooked up in this pic. Have you double checked them? Have you tried starting the PC by bridging the appropriate pins with a screwdriver or other metal object?
Why is the GPU in the lower slot?
In the future please give your thread a real, descriptive title. There's like 20 "help me pls u gaiz" threads posted here every week, a meaningful title will make people more likely to take a look and give you advice.
