My dumb cat had a wonderful time chewing along the whole strip of the power cable.
No punctures from the looks of it, though I want to replace it for safety concerns sake.
I tried looking through the specs of the ROG-THOR-1200P to figure out what kind of specs the new power cord needs to be.
I'm no electrical engineer, so I am hoping someone here can point me in the right direction on a computer power cord on Amazon.
need that to be at least 12 feet so the cord to the stupid thing goes up my standing desk rather than on the ground and being a tripping hazard.
If it is highly unsafe for a power cord to be this long to a 1200W PSU, just send the recommended length instead.
tl;dr Need help finding a 12-foot-long power cord on Amazon with specs that are compatible with the ROG-THOR-1200P.
Are we talking the cord that plugs from the wall socket to the PSU? If so, these cables are universal, and there isn't much difference variance from cable to cable. I have an entire bucket in my basement that are used for everything from monitors to PCs. Any generic PC power cable will do. They are essentially just glorified extension cords specifically for computer components.
Assuming you are in the US: the thickness of the copper wire inside the cable is measured in AWG (American Wire Gauge, often just called "gauge"). The more draw on the cable, the ticker you want the physical cable to be to avoid heating the copper itself.
18AWG cable is rated for 1200W (10A @ 120v). Given you will very rarely actually get to 1200W draw on your PC, you should be fine with that. If you want to get something a bit over the top, you can get a 16 or 14 AWG cable. (less is more. 16 AWG is rated at 13A, 14 AWG is 15A)
ask me about my homelab
on a personal quest convincing the general public to return to the glory that is 12" laptops.
cheap and easy cable management is my fetish.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
