how to get 3.5mm headset mic to work
sternmouse
Yes i know the whole 3 ring/ 4 ring story and mine is 4 pin ( rzaer barracuda X )
my question is how do i  how do i change ''headphones'' to ''headset''
image.png?ex=65b4cfbc&is=65a25abc&hm=d0fc922f4a0b9138442dcf43fa045adf96cacf2e613f7178e1c6f9e067892924&
this is because i have use it as headset before and that way it registered the mic as well
now with all these new updates idk how to change it back
Realtek audio manager from the looks of it, click your appropriate aux in port and change to headset
Alternatively, use a headset splitter, one to headphone input the other to microphone input
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
oh but both my wire and headphone jack are a headphone-mic combo
Yeah, im the same, ive got a kraken, but it came with a splitter as it can use the individual ports that specialise in both the mic and the headphones allowing for more customisation for both etc
Or, again, you can change the input to headset instead of headphone if thats more of what youre looking for
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Check the Realtek control panel to make sure the port you're plugged into is set to act as a headset.
If your device doesn't have a headset port, you'll need a splitter like this to break the TRRS connector out to separate headphone and microphone ports.
