Corsair Cable Compatibility
Go to solution Solved by seon123,
All RMx PSUs, regardless of wattage or version (other than the RMx Shift) use the same cables, Type 4. The only difference between Type 3 and Type 4 is that the 24 pin connector has 4 extra pins on Type 4 cables (but is still otherwise compatible if you jam in a Type 3 cable into a Type 4 PSU). So the RMx can use Type 3 and Type 4 cables, but the 24 pin is Type 4.
I have read numerous posts and watched a couple videos and tried to understand this funny chart. But I just don't get it. There is no source/destination PSU and they put a red dot(meaning type 3) into a row that says type 3 already. So it's either redundant or I don't know what I'm talking about. It also shows type 3 and type 4 under a single column, meaning a single line of PSU's can use both?
https://www.corsair.com/ca/en/s/legacy-psu-cable-compatibility
Can I get a real explanation on how this thing works?
I have an RM550x and want to upgrade to an RM750x or RM850x. I should be fine (I think), but I'd love to just know how to read this chart.
Thanks!
https://linustechtips.com/topic/1550757-corsair-cable-compatibility/
Thanks for the explanation.
According to the chart then, RM2019, RMi, and RMx are all compatible? They have the same dots of the same colour in all the same spots. The colours make things confusing, because I feel like they could all just be checkmates in this case.
Is that correct?
Is that correct?
Yes, that all sounds correct.
Is that correct?
You do know when you buy a psu it comes with its own cables right?
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
I do, but it's an ITX motherboard with a big cooler and I don't want to remove the huge cooler and repaste the cpu and re-manage all the cables if I don't have to. I just rebuilt my PC a few months ago and didn't want to do it again. That's all.
