I currently planning an upgrade that will slowly take place over the next year.
I would be taking parts from this list
https://uk.pcpartpicker.com/list/9QBNsh
Step 1 : buy psu,mobo,cooler,network adapter and case
2: put in old ram cpu and gpu
3: use and then slowly add rest of parts
If you have any ideas on how to make this cheaper or better please let me know because I am unsure
https://linustechtips.com/topic/1549858-upgrade-advice/
This is super vague, can you provide more details of what exactly you have and the end goal.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1549858-upgrade-advice/#findComment-16263994
4 minutes ago, Wallet_Warrior said:
Sry for lack of clarity
right now I have an acer nitro with a 10400f and a 1660 super
My end goal with this is to create a system with a larger upgrade path than an acer nitro as well as put components into a good airflow case
At least to me it doesn't make sense to spend ~360 for no performance difference. I'd wait till you want more performance and upgrade then.
If you want more speed, I'd keep the acer nitro, and put a 4060 or a faster gpu in it.
https://linustechtips.com/topic/1549858-upgrade-advice/#findComment-16264010
Im not sure the psu can handle it but I think it can handle a 3060
https://linustechtips.com/topic/1549858-upgrade-advice/#findComment-16264018
