Wall PSU cable burned
Veim
So i was just trying to use my old PC, change the GPU,and when i press the power button, the cable burned down, is my PC componet Will be fine ?, cause i didnt smell any burned scent, not Saw any smoke inside the PC
There are a lot of possibilities, can you provide me pictures? By "wall cable" do you mean the power cable connecting the PSU to the grid?
Define "burn". Did it melt, catch fire, something else? I would assume that your PSU is toast and not use it again. Might also want to get the wiring in your home checked tbqh.
Aerocool DS are the best fans you've never tried.
It melt, but Will my pc be fine ?
Yes
