How much space is needed between my GPU and my case
8 hours ago, Dextter said:Thank you, I currently do not have the money to buy a new case. What would you recommend then?
Would my thermals be bad enough with the 3 fan to where I would have to get a 2 fan version of the 7800xt so there would be enough space?
If you were to play it safe, then I'd choose the PowerColor Fighter variant since it's just 303mm and have 43mm extra space between it and the front fans.
Just on a side note, I had a NZXT Phantom 530 and an NH-D15 CPU cooler and even though they stated the max height was 183mm, my 2nd fan over the RAM slots was just touching the side panel on the case and still closed just fine.
So, if you want to go for it, then I'd get with the PowerColor Red Devil and see how it goes with installation.
