No unified audio?
Gat Pelsinger
From a while now I have been considering to buy new and good quality headphones, but I just realized that just good headphones doesn't mean good audio quality. The sound card is also involved. On my newer laptop, I think the sound is pretty decent (not the speakers, the wired audio), but if I try with the same earphones on my older laptop, I hate the audio quality I get. I adjusted all sound and equalizer settings but they are just inferior to my newer one. So, now I am wondering that if my sound card itself is worse, then there is no point upgrading to a good quality headphone. I just won't be unlocking its full potential. So, is there I way I can get a more unified audio experience such that the whole audio is tied to my headphone or externally something and that it is same across all devices?
Microsoft owns my soul.
Also, Dell is evil, but HP kinda nice.
Laptop can be hit-or-miss with mediocre/decent soundcards.
FYI a soundcard is just layman term for a DAC/amp (among other things - I'm not an expert).
The DAC could be poorly implemented resulting in poor noise and quality. This is common since laptops are compact, noisy environments. Secondly the amplifier could be poor and thus adding more noise to a bad signal. The amplifier brings the signal to an audible level.
You're looking for an external DAC/amp like the $9 Apple USB-C to headphone jack dongle. This isn't a joke - it's an extremely well-made DAC/amp performing better than many products 10x-20x its price.
If you want something better and more endgame without falling deep in the audiophile snake oil rabbit hole, you can look into the JDS Labs DAC and headphone amp options.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
It's not snake oil for DAC/amps worth thousands of dollars they are just super super super carefully made with the highest quality materials with a meager increase in sound quality. Snake oil "audiophile" products would be cables marketed as better sounding only because they have 0.01% cleaner metals or something bs like that. I do think that DACs or amps that are expensive over like 300 dollars would be stupid to buy anyways.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
I just personally consider it snake oil because there's no practical difference, even if literally speaking it may be better. If the improvements are entirely outside of human hearing/perception, does it matter? I mean this in the context of personal listening. Obviously equipment/instruments have their purpose within settings where incredibly accurate performance is required, but people aren't asking for that when they're asking for home audio listening.
I agree
AKG P420 Mic
Other peripherals
I can tell you that my $4-500 dac and $4-500 amp do indeed add sound quality, that's the SMSL SU-9 and Topping A70, BUT I can't say it's worth the extra cost to everyone.  The reason I got the dac was I needed something with BT and since I'm getting a standalone I might as well maximize what my funds could get at the time.  Same thing for the amp which I bought several month's later, I just wanted something with enough power to drive every headphone I have, and I have a couple that are very very dificult to drive.  Basically I'm going to have a listening station where I can listen to speakers or headphones while I watch my fishtank.  Now that I'm setting up, I got out my oldish topping dac/amp and along with a power amp I have my desk set up.
I can certainly hear a difference when upgrading quality and price, but it's diminishing returns.  Most people are better off just having a competent dac and amp to begin with then improvements can be had with headphones or pads, not dac's and amps.  But this is a hobby for me so it's worth it.
Everything @saintlouisbagels said is correct.  What you need is an external solution, I personally enjoy the schiit Fulla because it is the absolute best bang for the buck, basically for the price of an entry level dac you are getting a competent dac And amp.  They won't drive everything but will blow your laptop out of the water, just don't get difficult to drive headphones and you'll love it.  Also the other recommendations made are good as well.  There is always room to go up, but I wouldn't go down from that in most cases.  The only exception being the sybasonic sd-dac, it's a little better than good onboard audio so I rarely recommend it, but for something with a poor solution like what you have, it's a great solution for a killer price.
Also doing audio from both laptops into the same device is pretty difficult, I think it could be done in software but I haven't gone down that rabbit hole.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
