Small wireless mouse for productivity, similar to MX Anywhere 3 but higher quality?
18 hours ago, Eiri said:I've never soldered anything, have no idea what I would even need to buy and I have decidedly below average dexterity. Are you sure it's still a good idea for me to attempt this?
Also, I have zero knowledge of mouse switches. Can you recommend something basic that wouldn't die too fast?
If there's a electronic repair shop nearby you can try asking them to do it for you, I don't think it should be expensive since it's pretty much a 1-2 minute(s) job, and only need like ... entry level expertise.
If anything, the dismantling of the mouse gonna take more time than the switch swap. You can just dismantle it yourself at home, and just give them the PCB & switches.
Although I do recommend learning some simple desoldering/soldering so that you can DIY repair, which will mean you don't have to buy a new mouse for just a switch / scroll encoder problem, and don't have to rely on someone else all the time.
Common favorite switches are :
Kailh GM8.0
Kailh GM4.0
TTC Gold
Huano Blue
You can find youtube videos reviewing them, the sound profile etc. Although sound pretty much change based on what mouse it's used in.
