Help! BSOD - I Think RAM related?
Have you ran memtest86 on one stick and a time?
"memory management" It ensures that blocks of memory space are properly managed and allocated so the OS, applications and other running processes have the memory they need to carry out their operations.
"IRQL_NOT_LESS_OR_EQUAL" probably memory as other causes are antivirus and device driver which is doubtful as well.
"System service exception" since you ran SFC then this should not happen again unless installation of OS (windows) is corrupt also checking by CHKDSK command or in file explorer error check for a quick one.
"System Thread exception not handled" calls for memory check as mostly a driver or hardware faulty BSOD.
"pfn list corrupt" more or less same and service exception and thread exception.
I'm gonna say memory I suggest running memtest86 one stick at a time. I've had a DOA ram stick out of a kit once before.
They are in slot 2 and 4 right?
I'm just basing off what the BSOD mean. If you can try other ram from a friend or something. Do so. If issue still persists and not on friends (whom ever) system. Report.
