1 minute ago, SocExperiment said:
I am getting an i9-13900k and heard that they run a higher temp, is the artic freezer 34 esports duo going to be able to keep up, or do i need to look into getting a new cpu cooler.
You need a MUCH better cooler. If you cannot fit a better cooler in a budget, you probably dont need a 13900k. a 13600k or 13700k would be a bit better since you can use the saved cost to get the better cooler as well.
Pretty much requires a 280/360mm AIO and some voltage tuning, or the best air cooler that fits in your case.
https://linustechtips.com/topic/1540688-i9-13900k-cooling/#findComment-16204689
If you're doing something that benefits from the 13900K over a 7800X3D, yes, significantly. Even if you're just gaming the Freezer 34 would struggle a fair bit, though it might still be alright depending on the game and how much airflow the system has.
If you've got the money for a 13900K though, you have the money for a better CPU cooler.
https://linustechtips.com/topic/1540688-i9-13900k-cooling/#findComment-16204691
Thank you for the feed back, it is in the buf
Budget, just wanted to make sure before I went a started getting things i might nkt need.
2 minutes ago, OhioYJ said:
I would get a new cooler. My NH-D15, in a case with plenty of airflow, still lets it get pretty warm at points. This is with a LGA1700 contact frame too.
Thank you for the feedback, it was very helpful
https://linustechtips.com/topic/1540688-i9-13900k-cooling/#findComment-16204693
Either choose one of the top air tower coolers (preferably dual tower), or a good 360 AIO. That poor esports can't handle it.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1540688-i9-13900k-cooling/#findComment-16205475
I guess the more pertinent question is why not get a 13600K and let it run on that cooler while performing damn near as good as a throttled 13900k even on water for cheaper?
It's a rare thing to need a 13900k.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1540688-i9-13900k-cooling/#findComment-16205522
