400W PSU for a ryzen 5 5500 and a RX6600?
svber
is this PSU enough or should I go higher? it is 80+ gold rated
A decent PSU can handle it, but most PSUs start at 550 (or even higher) now, which suggests it is old, or not very good.
If you already have the PSU on hand and it isn't terrible, then I'd just try it.
16 hours ago, seon123 said:
There are 66 different 80+ Gold rated 400W PSUs. Which one of those is it?
it's a be quiet! Pure Power 11 400 W 80+ Gold
Seems like a reasonable model  -B tier if I read correctly: https://cultists.network/140/psu-tier-list/
I'd give it a shot.
Ran a 4070 + 5600x on a 460w (platinum) with no issues.
And the 4070 seems to pull 30-50 watt more than the 6600 xt
https://www.guru3d.com/review/geforce-rtx-4070-review/page-5/
mITX is awesome! I regret nothing (apart from when picking parts or have to do maintainance *cough*cough*)
More than fine
