Firewire to USB cable
Solved by jaslion,
firewire to usb cables don't exist. That's just not something they can do.
The only way to do it is to get a thunderbolt 2 (yes 2) dock WITH firewire or tb2 firewire adapter and have a thunderbolt capable pc. Then convert thunderbolt 2 mini dp to usb c thunderbolt.
Or if you have a desktop add a firewire addin card.
Either way firewire to usb DOES NOT exist. They are 2 ENTIRELY different protocols and need a translation layer between them. Best it can do is charge.
So yes you have been scammed
