RTX 3070ti Overheating
12 minutes ago, kittyducky06 said:Can you explain the whole pressure thing? Ive never had enough wattage and a small enough case for it to matter.
LTT has a couple great videos on it, and I know GN also has some actual smoke testing to show the benefits/disadvantages of each, but in short:
If your intake fans bring in more air than your exhaust fans can remove, then you get a positive air pressure in your system. Air is forced to leave the case from small vents, holes, perforations.
Negative pressure means you have more exhaust than intake. I've never had good luck with negative pressure.
Balanced pressure is when intake = exhaust, which is practically impossible. But you can get close enough.
In the situation of your computer, there is one intake and no exhaust fans. So effectively you are expecting one single fan to do all the air flow in your case. Your CPU and GPU (and PSU) generate heat but it is expecting that one single intake fan at the front to remove it from the case, and you are also expecting that fan to provide fresh air to your coolers. It isn't big enough to do both. And especially now that I see it's a Noctua fan... you are expecting it to operate quietly. Eventually that heat builds and your system runs hotter. That fan can't do it all alone.
Edit: I also think you are correct about the power (wattage) in a small case. I think ATX builds are more forgiving since air space is not at a premium. And frankly newer components just run so much hotter. I came from a 5820k and 1070. At that time they were hot, but there was no wrong way to configure your case. Compared to modern components like my 12700k and 3070ti, goodness it took me about three months of toying with fans and moving components to get my current thermal behavior.
