Hi,
I need an easy cooling solution for a 5800X. I have a NH-D14 from Noctua and this doesn't seem to be enough. I need a new easy to install solution that cooles the processor down as much as possible. So I can sleep at night. IDLE temps of 30 ° C and max of 70 ° C are the goal.
Please no custom water block solutions or something that would require setting up a whole water cooling system. I have 2 left hands when it comes to this.
Just a very easy to install solution. Thanks!
https://linustechtips.com/topic/1533844-easy-cooling-solution-for-5800x/
27 minutes ago, P3rform3r said:
Hi,
Idle 30C on a 5800X seems unrealistic/unachievable without doing something utterly insane.
What are the current tempritures?
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
Not at all. Absolutely believable. Let me guess.. you have an AIO 🙂
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
My AIO is only a recent addition and only on 1 of my machines. None of my AMD machines Idle at less than 40-45.
Useful Websites:
Bio:
Fun Facts
28 minutes ago, P3rform3r said:
Hi,
Can you give us a bit more information as to why the NH-D14 is failing you? The 5800x could run hot under full load, around 90c. But your current cooler should be plenty enpugh for it. I wouldn't buy a new one until I figure out what's going on first. Maybe you just need some voltage adjustments.
35 minutes ago, P3rform3r said:
Hi,
A graphene thermal pad like the Thermal Grizzly KryoSheet would probably solve your issue when paired with a PBO offset of negative 20.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Idle temp literally does not matter as long as your max load temp is withing spec.
Actually it's (in theory) better to have high idle temp and small difference between idle and load temp as you're not thermal stressing the physical properties of the silicon by heating it up and cooling it down constantly.
You want it as cool as it can so it can maintain boost. You don't want a high idle temp lol.
What is your case?
Do not care about idle temps they dont really matter
Also te 5800x simply just runs HOT and anything under 95c is totally fine.
70c full load basically means you need to undervolt even on a custom loop I recently did the 5800x BARELY stays under 65c with a undervolt. Not due to lack of trying since its 2x 360mm thick rads + p12 fans and all that.
D14 was good in its day, I had one. But there is no place for it today.
Everyone says that about the 58X3D too.
Just think, this is a stock CPU he has, very easy to cool.
It is not.
Like not at all.
The 5800x is a singe ccx chip basically being blasted to hell and back to run so fast. Pretty much the heatspreader wasnt designed for this so its a unique case of powerfull single chip cpu deviating from the ryzen norm causing it to run hotter.
The 5800x3d is all that + a extra cache layer on top of the ccx which means even more resistance of heat transfer to the heatspreader.
Pbo negative 15 + max allowed undervolt = 5800x3d at 4.4ghz stable at 75c on a dual 420 rad lian li custom loop pc from last month.
Its legit just normal for this thing and its meant to just run hot as it willeasily do full power in its normal 95c well safe limit
3 minutes ago, jaslion said:
It is not.
Like not at all.
I know my signature says 5900X, but I also have an X3D, so I am not just talking out of my butt 😄
Don't make me install it to show you how cool it runs 😄
Edit:
Too late, gonna install it, be back soon 👍
Edit:
Make sure to turn pbo and all off 😛
Why?
2 hours ago, P3rform3r said:
Hi,
Follow the instructions about PBO and undervolting. If you overclock, be conservative.  Post before and after benchmarks here.
If that doesn't help, turn off PBO, don't overclock and just undervolt it. Again, benchmarks before and after.
If that doesn't help, repaste the CPU and tighten it per the manufacturer's instructions. Again, post benchmarks if you have to do this.
I really feel you will probably need a better cooler. Take a look at the size constraints of your case, mobo, RAM, etc. Look at TR PS120, PA120, FC120, DC AK620, AG620, bq! DRP4, NH-D15 and other top-end coolers.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
I had this conversation with a guy at OCN already. He had a nice loop and I was getting better temps. If I disable PBO I might as well overclock it to the 4600-4700MHz range, temps will be the same.
Just running some OCCT give me about 10 minutes..
Ready for some heartbreak?
Right, my flaming hot 5800X3D 🤘
Isn't that for @jaslion?
It was.. I figured he would have been waiting for me 😄
1 hour ago, A_DeafMute said:
I don't know what you are trying to prove with a stress test that doesn't max out the power limit, let alone pull any meaningful amount of current.
Well, it is an X3D.. Who runs their X3D at 140w PPT loads? I could have shown you mine at 80c with that load, but the CPU turns my system into a Dell, no fun.
Not sure why you are even posting in this thread, unless it was just to call me out.  Great first post 🖕
Here is 245w from my 5900X instead.
4 minutes ago, A_DeafMute said:
Only posting because you were clearly using a bad/misleading example. As for your 5900X, I don't know what that has to do with the OP.
Your initial post was to be a dick. Nice try.
35 minutes ago, A_DeafMute said:
Everyone has to start somewhere, and i was only pointing out a fault in your example of a 5800X3D running cool, which you yourself installed into a system just to "prove" your own point.
If you take it as me being a dick then i don't know what to say.
The point I proved is that X3D does not run hot lol. Besides, the last post in this thread was 5 days ago.. seems like a great time to add your 2c 😄
9 minutes ago, A_DeafMute said:
You never know when someone comes looking through searching for "5X00(X) runs hot" or "Cooler for a 5X00(X), and just because the thread is "old" doesn't mean you can't add information to it.
We see that when someone posts in a 10 year old thread too 🙂
