Screenshot2023-09-25030522.thumb.png.5f1611b36e2a0412e003a962de79a6a2.pngim trying to move my recovery onto a different storage device. but idk how to do it. is there an easy way to do it?
if drive that has the black box around is unplugged the nvme SSD i have as my bootdrive completely dissappears and the pc acts like it wasnt there but if i plug it in it magically reappears if that makes sense.
https://linustechtips.com/topic/1532921-need-help/
are you talking about the "recovery" drive/partition? if so then no. The partition is created when installing the OS. If you're just talking about a backup then it should just be a regular files that you can move anywhere.
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor
CPU Cooler: ASUS ROG RYUO III 360 ARGB White Edition All-in-one AIO Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z490-E GAMING ATX LGA1200 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 Memory Boosted to 4400MHz
Storage: 6 various HDDs and SSDs
Video Card: ASUS ROG Strix 3090
Case: Lian Li O11 Dynamic XL
Power Supply: Asus ROG Thor 1000w
Operating System: Microsoft Windows 11 Pro
Monitor: Samsung Odyssey G9 OLED 49"
Keyboard: Logitech G915
Mouse: Logitech G502 LIGHTSPEED
Headphones: Sennheiser RS 175
Mic: Blue Yeti
https://linustechtips.com/topic/1532921-need-help/#findComment-16147464
so i would have to do a new install of my OS? which im fine with if can make it so my ssd is the recovery drive instead of 7yr old hhd
https://linustechtips.com/topic/1532921-need-help/#findComment-16147465
If you're okay with it then reinstalling your OS to your SSD should've been the first thing you did when you got it. So yes, the only way to do what you're asking is to reinstall your OS onto your SSD and your recovery drive will also be installed on the SSD. Also your old recovery drive will not go away nor will you get the space from it back on your HDD without basically deleting all partitions and reformatting the entire drive. And if you do reinstall windows to your SSD, fun tip... remove your old OS drive prior to installing or else you'll be prompted with dual boot every time you start your computer.
Mic: Blue Yeti
https://linustechtips.com/topic/1532921-need-help/#findComment-16147468
okay, somehow I completely missed the photo in your post...
that E: drive, as you do, I'd assume is your recovery drive. The only reason that would be on a separate drive other than your OS drive is if you have your OS installed on the drive prior. in which case Windows doesn't actually know that recovery drive exists for it's intended purpose. either that or the E: drive is actually a partition on your SSD already.
If you can open up Disk Management and see what all partitions you have and maybe post a picture of that here.
*edit* also either windows doesn't do it anymore or it's only SSDs but your recovery drive shouldn't actually have a drive letter attached to it and you should be able to see it in "my computer"
Mic: Blue Yeti
https://linustechtips.com/topic/1532921-need-help/#findComment-16147470
https://linustechtips.com/topic/1532921-need-help/#findComment-16147472
Yupp, as I suspected. See that "Healthy (recovery partition)" that's your NVME that was created when you installed windows on your SSD. so you can, if you want, just delete the other partitions you have on the other drives.
Mic: Blue Yeti
https://linustechtips.com/topic/1532921-need-help/#findComment-16147475
Yupp, as I suspected. See that "Healthy (recovery partition)" that's your recovery that was created when you installed windows on your SSD. so you can, if you want, just delete the other partitions you have on the other drives.
okay im also doing a full copy of my os onto a backup hard drive so ill have all my files for when i do a fresh OS
https://linustechtips.com/topic/1532921-need-help/#findComment-16147479
You don't have to do that other than just for the sake of having a backup in general. Every time you do a clean install of windows (at least on the same drive) it puts everything into a windows.old folder. There's not really a reason to format the drive or to delete partitions prior to a reinstall either. Nor do you want to carry over any old OS files to the new one. But if that's what you're used to doing then by all means it's probably best to stick with that.
Mic: Blue Yeti
https://linustechtips.com/topic/1532921-need-help/#findComment-16147484
Software like acronis or macrium can move the windows "special" partitions to other drives pretty easily. No need for a complete reinstall.
https://linustechtips.com/topic/1532921-need-help/#findComment-16147546
