My power supply isnt working after graphics card swap.
Solved by SorryBella,
6 minutes ago, jsnotlout1 said:the 1060 6gb in it broke, and i replaced it with a 750ti. All was well. I decided to try the 1060 now that all the drivers had been sorted out.
...so you try a broken card intentionally even when you know that the card is indeed broken?
Try back with 750Ti, damn with you not being able to game. Lets hope its just OCP trip and not a short.
