ubuntu How do I adjust AOC monitor brightness in Ubuntu
Solved by Bonk Cypher,
Thank you for your suggestion @E-waste on how to adjust colour settings via the OS. I have managed to find a solution for adjusting brightness via the OS which integrates with GNOME quite nicely, and works with Wayland.
The AOC monitor buttons are just annoying to use because you can't see the buttons, and have to blindly adjust settings. It's much more convenient to adjust brightness via the OS.
Anyway, the solution I found was to download the Brightness control using ddcutil GNOME extension. This this to work, you'll need to also follow the instructions on their GitHub page as well, to setup ddcutil
