Diagnosing dead parts after ripping CPU out of socket
Hey, so I ripped my CPU (Ryzen 9 3900X) out of its socket the other day when trying to swap the cooler. I then spent two days trying to separate the two (it was like I used cement instead of thermal paste) and bend the pins back in place, eventually it came off after I heated the cooler up with a hair dryer and applied A LOT of twisty force. I've put the CPU through hell to get it off so I honestly don't expect it to have survived. After plugging it back in and giving it power, the lights on the motherboard turn on (Asrock SteelSeries X570) but the power button does absolutely nothing. Not even case fans spin. Behaviour is the same with and without the CPU installed. I'm wondering if this means the motherboard is dead as well?
I have a spare system on the same platform but am not willing to try swapping parts because I need *something* for my job. Aside from this I am also cautious of damaging parts through association (or also ripping the CPU out of the donor system's socket too...). I'm compiling a list of parts for a new build and was thinking of just taking the plunge to upgrade everything, but a part of me wants to salvage what I can. I've seen similar posts in the past with mixed success (I'm surprised its anything higher than 0%). Is it a safe bet to assume that both CPU and mobo are dead?
Thanks 🙂
Nothing should be dead.
Have you checked your PSU power switch?
Connected everything?
The CPU isn't that easy to kill, maybe you're missing a pin or one is still bent, recheck.
Make sure to re-seat the RAM and clear the bios.
Feel free to try the CPU in the spare PC, nothing can go wrong.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
It is vanishingly unlikely you could have damaged any other part through what you did to the CPU.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
What thermal paste is that? We should make sure to avoid it wholly as a brand.
It's less of an issue with thermal paste and more of an issue with AMD's socket design. This has been a problem dating way back into the late 90s and early 2000s on AMD sockets up until AM5.
Because of how AMD's CPUs and sockets were designed, if the thermal compound isn't warmed up a little bit before the cooler is removed, it's possible to rip a CPU out of the socket when you remove the cooler. The only ways to avoid this problem on AM1-AM4 are usually to heat up the thermal compound in some way before removing the cooler(such as running a stress test on the CPU) or forgoing thermal compound entirely.
Pretty sure it's just mostly surface tension & the lack of heat before removing cooler.
Concave ihs might also contribute in strengthening the surface tension
Refresh before you reply
Happened to me as well with my former 3900X, it worked ok after unbending pins, cleaning the paste that spread all over when it slipped from the block after being ripped off, and when I finally put it back in the socket the right way, I was so pissed off I didn't slot it properly at first ... 😜😜
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Seems like that been would have that installed beforehand would have avoided the problem:
Or maybe not, perhaps it would have crushed the small parts on the sides of IHS when trying to lift "glued" cooler.
I edit my posts more often than not
In a shocking turn of events, as I was packing it away I reinserted the CPU and heard a crunch, it felt more stable in the socket than before. So I attempted power on again and it came to life, so I deconstructed the spare I was using this weekend, put its original parts back in and installed that the new cooler. It POSTs and has been online for the last 30 mins. Time will tell I suppose, I remember reading someone's story where the chip was only able to do like 5% of its original workload, I ran a passmark benchmark and got around 29k for the CPU alone (about 10% under the average).
I'm gonna go make the most of the last of my stressful bank holiday weekend. It's been a rollercoaster. Thanks for the advice! I'm very paranoid when it comes to these things, would always rather cut my losses than risk breaking more stuff (although by the sounds of it, this was never a risk).
In terms of the thermal paste used, I'm guessing it was either the stuff that came with the stock cooler or Noctua NT-H2. I would agree with replies on this thread that its probably a mix of attempting the swap cold (lesson learnt there) and that its been near enough 100% usage 24/7 for the past 3 years. It had been edging 90C in recent weeks and sometimes the fan needed help to spin and would prompt thermal shutoffs (hence the need to replace the cooler)
