1440p gaming PC from scratch for 1600€ : build review
54 minutes ago, Bastoise2000 said:Also, the motherboard you recommended doesn't have wifi. Is it easy to add a wifi card onto a build ? Will I need to check for specific ports or anything like that ?
Ah , sry i missed the fact u dont have access to wired Ethernet.
Ok well u can forget the whole white aesthetic and just grab a wifi equipped Motherboard like the Gigabyte B760M DS3H AX, or keep with the white aesthetic and get the ASRock B760M Steel Legend WiFi for 25 euro more.
54 minutes ago, Bastoise2000 said:(everyone else is recommending upgrades to the GPU, so I need to think about it).
Aye ideally u'd get at least the 6800XT , good performance level and its good bang for buck, however since u need a monitor as well it makes it a bit harder to fit a good GPU choice AND a suitably balanced Monitor at the same time.
Not that there is anything wrong with a G27Q + 6800XT, its just that many people like upgrading to an ultrawide at some point, u have the possibility to do that now and "build into it" in the future with a GPU upgrade as games get more demanding. if ur not into ultrawide then there isnt anything wrong going with the G27Q.
Ultimately, any1 serious about PC gaming, which would include someone willing to spend 1600 euro on a PC :P, should be aiming to eventually get a top tier Monitor which nowadays means, OLED. Building a beast of a PC to set game settings to max or near max only to be let down by a display that cant give you the full experience , is a waste.
If ur fine with the g27Q perhaps you should consider the following.
CPU: Intel Core i3-13100F 3.4 GHz Quad-Core Processor (€129.43 @ Amazon France)
CPU Cooler: Deepcool AK400 66.47 CFM CPU Cooler (€34.29 @ Amazon France)
Motherboard: ASRock B760M Steel Legend WiFi Micro ATX LGA1700 Motherboard (€179.95 @ Amazon France)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€122.88 @ Alternate)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (€49.99 @ FNAC)
Video Card: XFX Speedster MERC 319 Radeon RX 6950 XT 16 GB Video Card (€629.00 @ Amazon France)
Case: BitFenix Nova Mesh M ARGB MicroATX Mini Tower Case (€64.95 @ Amazon France)
Power Supply: Cougar GEX 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€110.19 @ Amazon France)
Monitor: Gigabyte G27Q 27.0" 2560 x 1440 144 Hz Monitor (€259.99 @ Amazon France)
Total: €1580.67
Generated by PCPartPicker 2023-08-12 18:48 CEST+0200
A 6950XT is a beast of a GPU, more than capable.
