Short PSU to fit inside CM Elite 130
Guest nightowl21
I need a PSU to fit inside the Cooler Master Elite 130 and the shorter the better. It needs to be at least 400W have active PFC, and be either full or semi modular since there isn't much room in the case. Anyone know of such a thing that's not expensive?
Budget? What are you powering?
I'm powering a core i5 4670, a gtx 660, 1 HDD, and one blu-ray drive
pcpartpicker list so far: http://pcpartpicker.com/p/3K7xR
I have this one and it is quite nice, not sure if it has active pfc, but it is cheaper than the cs series:
http://pcpartpicker.com/part/corsair-power-supply-cx430m
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
 yes it does. thanks guys for helping me find a good psu. looking for the best best PC component can be tedious.
