I had just recently built a new computer with a 4060ti (8gb) everything was running perfectly fine i would run valorant on 350-450 fps but just yesterday i was running it on 150 fps. Its not just valorant aswell, Destiny 2 I was running 150 fps but now im running it on 75-50 fps. I have no idea how this was caused and its scaring me because i fear that my gpu can break any day  now.
https://linustechtips.com/topic/1523474-4060ti-low-fps/
It cant be my CPU because I have a i7 13700k.
https://linustechtips.com/topic/1523474-4060ti-low-fps/#findComment-16060136
I'd install HWinfo64 and see if you're thermal throttling on the CPU. Comboing a 4060ti and a 13700k provokes concern about the other hardware choices made, including providing proper cooling to a 13700k.
I'd also recommend a full parts list and potentially photos so we can tell you what might be afoot.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1523474-4060ti-low-fps/#findComment-16060156
Motherboard: MSI MAG B660 TOMAHAWK WIFI DDR4
CPU: Core i7 13700k
GPU: ASUS DUAL FAN RTX 4060TI
CPU COOLER:  COOLER MASTER HYPER 212 RBG BLACK EDITION
SSD: SAMSUNG 980 PRO (1TB)
RAM: CORSAIR VENGEANCE RBG PRO DDR4 (32GB) 3600MHz
PSU: CORSAIR RM750X (750W)
CASE: PHANTEKS G360A
https://linustechtips.com/topic/1523474-4060ti-low-fps/#findComment-16060189
CPU: Core i7 13700k
The hyper 212 is quite an old cooler, where I can see it struggling with a 13700k in standard configuration. You're probably thermal throttling on the CPU enough to drop the framerate, so I'd validate that with a software like HWinfo64 before messing with any hardware.
https://linustechtips.com/topic/1523474-4060ti-low-fps/#findComment-16060216
an update! so I've opened up my side panel to see that the gpu fans arent spinning would this be the problem?
https://linustechtips.com/topic/1523474-4060ti-low-fps/#findComment-16060218
They'll stop spinning under low load, like if you're not running a game or the GPU isn't drawing much power. If its happening while you're gaming, then something is likely limiting it, since its less likely that both GPU fans have failed.
https://linustechtips.com/topic/1523474-4060ti-low-fps/#findComment-16060221
ive figured out the problem and im honestly embarrassed for wasting your time. Turns out it automatically put my game at 4k resolution which is bad for a 4060ti I apologize I should have figured this out within a second. @Agall
All good, sometimes it just takes asking some questions to another person to point you in the right direction, directly or indirectly 🙂
https://linustechtips.com/topic/1523474-4060ti-low-fps/#findComment-16060567
