Even if someone told you what it is and where to get it, could you realistically repair it yourself? If you don't know what it is, chances are you don't know how to repair it.
Just take it to a repair shop and ask them.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1522950-help/#findComment-16056714
Had something similar happen to my 2080ti and even having the part number I couldn't find anything anywhere. Went as far as asking the manufacturer (EVGA) and they basically said the parts are in-house only and couldn't be sold. In my case the parts were no longer manufactured at all and there was no way to repair the card.
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor
CPU Cooler: ASUS ROG RYUO III 360 ARGB White Edition All-in-one AIO Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z490-E GAMING ATX LGA1200 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 Memory Boosted to 4400MHz
Storage: 6 various HDDs and SSDs
Video Card: ASUS ROG Strix 3090
Case: Lian Li O11 Dynamic XL
Power Supply: Asus ROG Thor 1000w
Operating System: Microsoft Windows 11 Pro
Monitor: Samsung Odyssey G9 OLED 49"
Keyboard: Logitech G915
Mouse: Logitech G502 LIGHTSPEED
Headphones: Sennheiser RS 175
Mic: Blue Yeti
https://linustechtips.com/topic/1522950-help/#findComment-16056766
I’m thinking of getting another faulty one for only 10$ and taking parts of it
https://linustechtips.com/topic/1522950-help/#findComment-16056800
4 hours ago, Echothedolpin said:
Looks like you blew a MOSFET. How much experience do you have with replacing SMD components?
I’ve got some experience I have a hear gun solder and flux and I’ve replace a cpu on my laptop motherboard I’d say quite some experience
https://linustechtips.com/topic/1522950-help/#findComment-16057187
You’re probably well-set in that department then! My only concern would be it looks like two damaged components, are they on exact opposite sides of the board? If so there might be multilayered PCB damage that won’t be fixable.
https://linustechtips.com/topic/1522950-help/#findComment-16057319
They are not directly opposite they are a few cm apart and what part is it and where can I get it
https://linustechtips.com/topic/1522950-help/#findComment-16057384
Let us know how the repair goes. I would Iove seeing a diy success story.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1522950-help/#findComment-16057414
What exact graphics card?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1522950-help/#findComment-16057419
31 minutes ago, Liam lost in tech said:
Twin frozr R7950 3gb/OC
I can't get any schematics for that board. Can we get better pictures of the components next to the blown ones? I'd like to be able to read the markings. I circled ones in blue that will give us hints to part numbers as long as they're readable.
image.png.2b495ce9438af2a9cb9512f6771d4bd4.pngimage.png.34cb560f2f572fdfe3f9f10c70902a64.png
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1522950-help/#findComment-16057532
  Reveal hidden contents
Here are the e best pics I could get
https://linustechtips.com/topic/1522950-help/#findComment-16057633
-snip-
I can't read it. What are the markings on them? I can figure out some letters and numbers, but not enough to get a part number.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1522950-help/#findComment-16057742
3 hours ago, Liam lost in tech said:
Ok so the first chip is 8510 756-01 U1139 second chip is 050NE2LS HAD125
A donor card you mentioned earlier might be cheaper to source parts from and would have extra caps and fuses as well.
I can't find a direct data sheet. If you wanted to just get that mosfet and the one to replace the second one, the easiest way would be to remove a matching mosfet and get some measurements off of it.
https://www.ebay.com/itm/285008204666
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1522950-help/#findComment-16058783
