What cables to use for SAS drives and HBA card?
1 minute ago, roelversteeg said:I am planning a proper NAS build but i am getting confused as to what cables i should buy to connect a HBA card to the SAS drives.
I will be using a LSI 9300-16i HBA card (will be upgrading to more drives later and found a good deal on 16i variant instead of 8i)
For the drives im looking at 6 Seagate Exos X16 10TB SAS drives.
So far i figured out that the HBA connector should be the SFF-8643 type.
but what i cant find anywhere is what the other end for the drives should be? If anyone could inform me as to what connector type i need for those drives, and where i can find such info in the future that would be awesome.
Maybe some (ebay / aliexpress) links to a correct cable would also be appriciated.
I wouldn’t use SAS drives…. Go with SATA. Easier, cheaper, more options, etc
You can go from a single SAS to 4 SATA ports with splitters you can easily find on eBay. This is standard practice and not a “weird, ghetto solution” so it’ll work great.
https://www.ebay.com/itm/133117291866?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=jFynvEpdSpS&sssrc=4429486&ssuid=B1xTkXm_Qfe&var=&widget_ver=artemis&media=COPY
