Lian Li 011 or EVO
venomx
Can't decide whether to get the standard 011 or the EVO version.
EVO has the option for rear exhaust fan and I heard the EVO has better cable management.
Also I'm uncertain as to whether the standard O11 can run two 140mm fans at the bottom as this diagram I found says it can only run 3x120s..
Does the Lian Li 011/EVO support a 240mm rad at the top of the case ? All the specs I have seen only mention 360mms
Thanks
if it supports 360 then it supports 240
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
Thanks for the useful info guys. Looks like I should go with the EVO then as it provides much more flexibility.
According to my UK supplier the EVO definitely supports 140mm case fans wheras the standard 011 does not..
STANDARD
EVO Version
i had problems with my evo so.. i would say something els. buy a knock off of the 011 cheaper and probly better...
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
I've got a new build of the 11d mini and there's a few things you can do to accommodate everything like the rad offsets. Great bit of kit.
What problem did you have with it ?
the front mesh kit was flimisy
the 140m fans were so close to the power button it bends it (best to only use 120mm on the bottom
the power rest was one connector instead or sepritly
have to take all the p annals off all the time
bottom fan mount was bent and fan hit it
for a $350 case im not happy with it.
if you like the look?
The Phanteks NV7 might be something you're into.
Just wanted to say thanks. Got the build done and really happy with the new case. Will need to get some fans to fill it out but its a work in progress.
