I just got a 2nd r9 270x for my system my mobo is a asrock fm2a85x extreme 4 and it has two pci-e slots both are 2.0 x16 slots but why when in crossfire top card reads x16 and the other card reads x4.  It stays that way while playing games and other tasks could any one explain this or is there a way to fix this ?? thanks
https://linustechtips.com/topic/152090-dual-graphics-not-running-same-speed/
Firstly, I apologise if the image is huge and stretches the page.
Secondly, do you see the solder points at the base of each PCI-E slot? The top slot has them all the way to the end, but the one lower down only has them part way along the slot. This is what's causing it to be read as x4, and cannot be changed AFAIK.ioyRDPP8MXwyQ.JPG
Yup. The socket is 16x, the connection is 4x. No way to change that.
Closest thing I could find was x16 with one and dual x8 with two http://www.newegg.com/Product/Product.aspx?Item=N82E16813130754
If you're gonna want dual x16, you're going to need to switch to another chipset. Heck, I'm not even sure if amd supports dual x16 (and if they do well I need to do more research xD)
I fix computers and computer accessories... sometimes... when I want to...
Or there's the Asus version of the same board that @178Sonic posted
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132054
EDIT: this one doesn't offer 3-way SLI/Crossfire, so if that's something you have then go for the MSI one (provided you do decide to change your board at all).
FYI Running 2 cards at 16x/16x will net you  1% in performance gains
ACS Systems - Jason Neal
My "Danger Den" PC: i7-4960x @ 4.5Ghz, ASUS X79 Deluxe, 3x GTX Titan Black, 6x m4 512GB, 64GB Corsair DDR3-2400, Corsair AX1500i
Black Beauty Workstation/LAN PC: i5-4570 @ 3.79 GHz, ASRock Z87E-ITX, XFX Double D R9-280 (Non-X), GSkill 8GB DDR3-2400
Nice pick O.o
is there a board out there that can support both cards running at x16 and with a fm2 socket by chance?
there are better boards for money
Thanks for all you help guys I ordered a new board this morning went with the MSI a88x g45 it will give me x8 for crossfire than x4 and ill be happy with that.
You wasted money, the performance gain is literally negligible. 1-5% at most.
They do, my am3+ MSI GD80 does 2 cards in 16x :)
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
That might even be over stating it.
There is a reason AMD says boards with a 4x PciE 3.0 slot are still crossfire ready. Because it has little to no impact and there have been more than a couple articles to corroborate it. (at least for pre r9 290 cards, I don't know if the extra communication over the bus might effect them but older card wirk just as well)
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
Yeah, people have run a 780Ti via Thunderbolt 2 (equivalent to 4 2.0 lanes), with almost no performance losses.
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
