i7-12700k not boosting
Try clearing the Disable Turbo box on the main ThrottleStop screen. Intel CPUs use turbo boost so they can reach maximum speed. Turbo boost needs to be enabled. Double check your BIOS to make sure Intel Turbo Boost is enabled.
Are you using the latest BIOS version? Problems like this are usually solved with the most recent BIOS update.
Your computer has Undervolt Protection enabled. This can cause huge decreases in performance. Run Cinebench and see how your score compares to other computers with the same 12700K CPU. I would recommend disabling Undervolt Protection in the BIOS if your BIOS allows you to do this. UVP is a broken feature that can cut performance in half.
ThrottleStop will not show Undervolt Protection in the FIVR window when this feature has been disabled in the BIOS.
