Bent cpu pin. Pictute below
Solved by Sjaakie,
1 minute ago, WestTexan said:I hope so! I'll only be using my parts again Monday or Tuesday when the case arrives.
聽
I've seen people cut off pins off CPUs and they still boot at least.
聽
Worse case scenario I have to bend it straight?聽 I think it'll be fine though.
You can carefully bend it straight with a thin knife or a credit card or something, but honestly it's such a minor bend that it would probably turn out worse
聽
聽
